Ah a man who has owned a Mini in his dim and distant past!dnb wrote:Marigolds for mutants would work better than tesco bags wouldn't they?
The cross ram set up is very good for a broad spread of torque however the assumption that goes with that style of one choke to one port is a high compression ratio and a fair amount of cam timing coupled with good heads, all would combine to make an engine that although good for general off road would be best used for a comp safari style car. I would go with the SUs they will give you the best engine performance for your money and make a hole in the back box.
