Page 2 of 2
Posted: Mon Apr 14, 2014 4:35 pm
by Coops
cheers mate,
http://www.ebay.co.uk/itm/8-Siemens-Mot ... 3f07fae503
so they will be ok and a direct replacement then?
as need to order this week as Phil has confirmed the injectors maxing out so before I go any further with the racing I need to get these sorted,
Posted: Mon Apr 14, 2014 5:23 pm
Either will be fine, just curious as to why the different part numbers and pictures of different injectors ?
Posted: Tue Apr 15, 2014 6:54 am
by daxtojeiro
Toni,
just remember, when you do fit your new injectors, you will change the req_fuel setting appropriately, but the whole VE table will need re-tuning.
In theory this shouldnt be the case, but it always is as injectors opening time characteristics change at different opening times, and the spray pattern will be different.
So dont just jump in it and start driving as you had been, start by logging it and keep out of boost until you get a feel for what needs changing.
thanks
Phil
Posted: Tue Apr 15, 2014 8:55 am
by SuperV8
Can't you just increase your fuel pressure?
The 044 should have enough headroom shouldn't it?
Posted: Tue Apr 15, 2014 9:08 am
Depends how much headroom you have or need. But it would be a free option.
Posted: Tue Apr 15, 2014 10:11 am
by SimpleSimon
daxtojeiro wrote:Toni,
thanks
Phil
I presume your hinting inj dead time Phil? 8-)
Posted: Tue Apr 15, 2014 10:16 am
by Coops
fuel pressure is 43psi
Posted: Tue Apr 15, 2014 11:44 am
And how much more fuel do you need ?
Wind base up to 65 or so. At 10 psi boost, that's still only 75psi tops
Posted: Wed Apr 23, 2014 9:05 am
by Spongo
I bought mine from a company call Trigger Wheels and they are a UK company, not a huge range but they do deliver quick
http://trigger-wheels.com/store/index.html
