which wideband should i buy
This is a long shot but does anyone know of a lambda sensor and gauge that can be used, and properly calibrated, to work with methanol?
sidecar
Post by sidecar »
kiwicar wrote:Hi
In the back off my mind somewhere I seem to recall that the LC1 can be re-calibrated via its laptop software but don't quote me on that!
That should be worth an investigate. . .
kiwicar wrote:Hi
My Tech Edge can, via software. For LNG. LPG, diesel, methanol, ethanol as well as unleaded, according the the menu. Not that I've ever tried it.
kiwicar wrote:Hi
Haltech sell a methanol specific wideband kit. Pretty sure it is the only one.
http://www.efi101.com/forum/viewtopic.php?t=4606
I can't see why you'd do a methanol specific one, since the sensor is the same? So it's only a question of how the electronics interpret the output from that?
DaveEFI wrote:I can't see why you'd do a methanol specific one, since the sensor is the same? So it's only a question of how the electronics interpret the output from that?
The fact nobody offers a wideband for methanol...means it must not be as simple as that.
The Bosch sensor is apparently not suitable, and even with the NTK sensor, it must be pushing it to the extreme's of it's range.
Obviously that advert is old, but for Haltech to claim they are the only company making a methanol wideband kit....that's a fairly big claim. The market maybe is smaller for methanol I guess, but if it was so easy loads of companies would be doing it, just as the other range of widebands.
Although reading through the thread on efi101 again...seems some dispute Haltech's claims and as some say, it does just look like NGK's own wideband.
As I said earlier, my Tech Edge DIY does.
As I understand it, the sensor only looks for the proportion of oxygen in the exhaust. Software tells it how much there should be for different fuels and computes an AFR. My Tech Edge unit allows you to use Bosch or NTK sensors.
I read it as it being the only exclusively methanol one. Whether than makes it somehow better than one which gives a choice of fuels like the Tech Edge, I dunno. You can download the Tech Edge software for free to have a look.
