sidecar wrote:Also in my humble the days of advancing the ignition until the engine knocks then backing it off a few degrees are long gone, this is a pi55 poor method of setting up the ignition.
I was originally confused by your responses, Pete, but you seem to have clarified the situation to support my methodology? Let me explain!sidecar wrote:Trace detonation is harder to detect and you won't hear it which is another reason for not pushing the timing up to the point of detonation then retarding it half a degree.
From your opinion, it's not acceptable to back of a few degrees and in the second extract it seems less acceptable to back off by a tad - 1/2 degree (say)?.
later in the thread is an enlightening explanation:
Hence my improved loss of confusion - If peak torque and optimum VE occur around the point where pinking occurs, how come my well explained empirical method to get the engine slightly away from the point of maximum torque and where only trace detonation might occur (with its resulting minimum of piston damage) was so seemingly bad?sidecar wrote:The reason that it is pinking at 3000 RPM is because that will be around peak torque and peak torque is where you get a peak VE, that leads to a higher peak cylinder pressure.
Throughout my explanation and advice I have emphasised the empirical approach helps to overcome the many variables in Chris' setup, bad CR, restricting air filter, confusing pulley timing marks, modified dissy advance curve, etc.
All this in response to Chris' request " -
What i suppose i'm looking for is that simple fix as its ran for 10+ years safely - i'm presuming its either something i've done or something that has worn very recently causing this - "
Pete, I appreciate that for some reason we appear to have crossed swords on this issue previously and I don,t really expect a continuing debate because
But now, encouraged by your above explanations, I feel confident that my process, as explained, will bring the timing on Chris' car very close to optimum, to avoid pre-detonation,and achieve peak torque and optimum VE.sidecar wrote:We have had this discussion before, you have linked to the same green text before, I can not be bothered having the discussion again.
