Real Steel Merlin F85 Heads
It's MUCH better to have a bigger inlet valve at the expense of the exhaust valve size. If you have a well designed exhaust you have a huge pressure difference across the valve, so it flows well regardless. You don't get a good pressure difference across the inlet unless you have some form of forced induction.kokkolanpoika wrote:Why so small valves?![]()
Rover Stage 4 exchaust is bigger.. but inlet is smaller.![]()
I´m disappointment those power curves.. I expect over 350bhp..
- desertrover
- Helpful or Confused
Hi there,
So what I see is, that they get a max of 353 lb/ft with a 4999cm³ engine.
That´s 480 NM.
Translated this to a 4554 ccm engine, it is 321 lb/ft. That´s 437 NM.
The standard "Thor" injected RR II engune gave 407 NM @ 2.600 rpm.
That´s an increase of 7,37 %.
Is that worth that money?
Is this not obtainable with goord worked standard heads?
That´s 480 NM.
- ihatesissycars
With worked standard castigns you can only seem to have top or bottom end, no in between, you can with the rs heads, they make good power all the way accross the rev range and in regards to cost they outperform and equivalently priced rover head and they are brand new and potential for more. The test engine that graph was for was a very rushed job engine so they simply had a figure for the kit car show they had a stand at, there is scope for more power. The cam was supposed to be quite mild too.
- desertrover
- Nick Moore
- ihatesissycars
- ihatesissycars
goodsy1968
Nope your not aloneNick Moore wrote:Would these heads be suitable for a 3.5, with Crower 50232, roller rockers, full balancing and alloy flywheel? Or am I the only one still playing with a P6 motor?
- Nick Moore
I'm guessing that the "F85" is some sort of homage to the Oldsmobile F85?
One thing I've seen pointed out on the Pistonheads website, the exhaust ports on the Merlins are higher than a standard Rover head, similar to Buick 300 heads, meaning standard exhaust manifolds or headers won't fit. That's not a criticism though, raising the ports is a good idea and if it produces better flow, I say good on 'em.
Still, either Real Steel are cunningly ratcheting up the tension and building excitement in the biggest advertising campaign since the Segway, or their sales department only works part-time. RS - we want lots of numbers and pretty pictures please!
It's not a bodge if no one finds out!
- ihatesissycars
http://www.v-8.org.uk/FORUM/viewtopic.php?t=1183
Theres some piccies on my thread about my own rs heads.
