AN/Thread size/type Hotwire Fuel Rail 2 fuel feed hose?
Cappucino-kid wrote:I'm having to make up the whole fuel line - I did ask on another post what the general feeling was on using all rubber fuel line or a combination of metal/rubber?
Take away costs and tooling required for making up metal lines is there any advantage in using them - manufacturers seemed to prefer it before plastic lines came in, but that could just be an assembly issue?
I used a rather crude method of measuring the internal bore of the fuel rail with a drill bit, I made it @5.5mm on the feed, and slightly smaller 5(?)mm on the return, not sure what that equates to?
Again, you need to be more specific. Inside the cabin, outside the cabin ? Will the lines be anywhere vulnerable to damage ?
Copper, steel, alloy, nylon, rubber and many others are all viable options. Whether they are suitable for your application is another matter.
