Hello all!
I was wondering if anyone knew of a step-by-step on how to go about supercharging my 4.6 RV8?
Ive searched online but you only seem to find bits and pieces. Or articles not relating to my engine...
If i could be pointed in the direction of a Rover-specific article or guide, it would be very helpful in my quest to know what bits i need to get a hold of and how to go about assembly etc..
Supercharging
- topcatcustom
Stuck In The Mud
Hello TC, and thanks for the quick reply
My 4.6 is in a defender 110. It is fuel injected and controlled by megasquirt and has EDIS ignition system.
Id rather the system be pretty quiet as i dont like really loud/whiny chargers - would rather listen to the bellow of my V8, and has to remain under the bonnet.
Well the hard-work is arguably done, namely you have fuel and ignition under control.
Scroll to the bottom of my manifold page for some supercharger setups:
http://www.mez.co.uk/ms12-new.html
You will need larger fuel injectors if you have not allready upgraded. 60lb siemens deka's fit straight it. Tony's capri thread has some discussion i believe.
That kinda rules out roots type superchargers.Id rather the system be pretty quiet as i dont like really loud/whiny chargers - would rather listen to the bellow of my V8, and has to remain under the bonnet.
Twin screw are quieter but very expensive - probably best response for a landy. Lots of low end torque.
Centrifugal can be quieter but also may hear a little gear noise - but I don't think the response would work well for a landy.
Why do you want a supercharger? Have you thought about turbos?
My rotrex charger is real quiet, all you hear under the bonnet at idle is a louder induction noise due to the air being sucked in,
Not sure what noise there is from outside when going down the road mind you
my install: http://www.v8forum.co.uk/forum/viewtopi ... 8525#88525
- topcatcustom
An Eaton M112 has got to be the cheapest, easiest to find and a relatively quiet option, my old chap has an XKR and the blower is pretty quiet, just a tiny whine to let you know it's there. There are loads of second hand ones available and should already have a ribbed pulley for your 4.6 serpentine setup, just got to modify an inlet manifold and/or mounts, sort injectors and some other modern rubbish! As Elliot said- you already have that under control so I think the biggest task is the hardware.
TC
