Before I go and investigate I would like to make sure I have all the bases covered for this fast idle. So can I run it by you:
1) Throttle potentiometer - to check correct voltage.
2) Would AFM send incorrect flap open signal? Are there any tests for this?
3) The guy who had it before me in his rangie had trouble running on petrol (it has lpg injection as well), which I am pretty sure was down to the loom which I have now rebuilt, and the top of the AFM had been removed at some stage. I seem to recall there being an idle screw setting in it. Could a garage have messed about with this when trying to fix the problem before and caused the problem - if so where is it and what does it look like?
Can't think of anything else, but suggestions welcome please.
Thanks.
