RV8 - Installation of Kenne Bell Rollers - Questions
adamnreeves
Post by adamnreeves »
Mine have different mounts ?
adamnreeves
Perry, I presume you must have outriggers and steel posts then?
Post by ian.stewart »
I see you have outriggers Pel, Are they too tight?, It looks like the are rubbing, I eventually dumper the springs, and converted to alloy spacers, and used thin spring washers to take up the slack, What mounts do you refer to?, Mine used standard pedestals, IIRC I had to turn the bolt heads down for clearance of the arms,
THE SMOKING GNU
Blown v8
Post by Blown v8 »
I too dumped the springs and went with spacers, I ground the bolt heads down aswell!
I run solid lifters on mine
adamnreeves
Blown v8 wrote:I too dumped the springs and went with spacers, I ground the bolt heads down aswell!
More by luck than judgement I bought some titanium bolts and they are only 13mm heads and have plenty of clearance.
Solid lifters. I think eventually I will go this route. Do you have cut-outs in your pistons?
Blown v8
Post by Blown v8 »
I do have cut outs, but no pics,as they were installed before camera phones were popular ! lol
I hope the bolts are necked to allow for oilflow up to the rocker arms ??
THE SMOKING GNU
adamnreeves
ian.stewart wrote:I hope the bolts are necked to allow for oilflow up to the rocker arms ??
They were. Good call though I shall check the dims.
adamnreeves
Blown v8 wrote:I do have cut outs, but no pics,as they were installed before camera phones were popular ! lol
Yep thought you would. I will probably leave my solid lifters and cam upgrade until I've put some nice forged pistons in.
ian.stewart wrote:I see you have outriggers Pel, Are they too tight?, It looks like the are rubbing, I eventually dumper the springs, and converted to alloy spacers, and used thin spring washers to take up the slack, What mounts do you refer to?, Mine used standard pedestals, IIRC I had to turn the bolt heads down for clearance of the arms,
I dont have the ally pedestals Ian. Its all steel stuff. The wear marks just look like the anodising has been cleaned off. They are not new items. And the have extra oil holes in them. I use later square covers with a spacer for clearance. But I dont like them because the dont have the MG logo on them :(
When i get the engine back together next week I'll be doing the tappets. Solid lifters fitted so what do i set the clearances at. I guess 30 thou all round will do eh?
I think I ran mine at 0.018" I also used early covers without a problem, but I ran a low lift cam
THE SMOKING GNU
Blown v8
Post by Blown v8 »
I set mine at 22 thou when hot
Works out about 24 thou cold
DaviesDJ
Post by DaviesDJ »
Ok guys, now winging its way to me are a set of NASCAR Carrillo used 6 inch rods for my new build! :-) going to grind my 4.6 crank down and offset to 89mm at the 1.85 inch diameter as required! Have been discussing options with mike(kiwicar) who has been great with advice. BUT was wandering what piston options to go for??? Wrist pin is 0.86, and I can have a comp height of much above 1.2-1.22 inch. Think the ford modular 3.7 inch big bore flat top/shallow dish is my best bet but was wondering if anything else is about??? Perhaps a bit bigger then 94mm??? Cos use a Chevy but don't like be idea of drilling out the small end/ wrist pin hole to .927 or whatever - seems a big jump taking away a lot of metal. Any thoughts??? Ohhh by the way, rods and bearings 144 dollars.
DaviesDJ
Post by DaviesDJ »
So sorry!! Thought I had clicked on my old thread!! Bit embarrassed! Sory for putting this on your thread guys
