T5 speedo drive - bung?
seight
Before I make a big cock up, do I need to fit some kind of bung where the speedo cable used to fit?
I'm going to use an electronic speedo with a signal off the diff bolts so I don't need the gearbox speedo. When I bought the box there was no speedo cable on it just what I guess is the drive gear housing sticking out of the tail casing. Up to to day I have just shoved a rubber bung in it stop stop muck getting in without really knowing whether it needs sealing properly to stop the gearbox oil emptying out. There's no facility for bolting a clamp on either.
From a bit of googling it looks like there may be several variations on the way the speed cable attaches. It looks like this one could be something thats held in by an internal circlip but I'm not sure and haven't seen any examples.
Any ideas?
thanks
Any ideas?
thanks
seight
Yes I think I'll do something like that. At the moment this is what I can see sticking out:
http://cgi.ebay.co.uk/FORD-COSWORTH-T5- ... 0525577933
seight
You're probably right it looks like that's what TVR did as I've found a TVR site that has a bung listed:
http://www.thetvrsite.com/files/parts-m ... earbox.pdf
For some reason though I don't have the retainer !!
Never mind, yet another job to sort out.
Unless anyone knows where I can get one?
Hi Mike,seight wrote:You're probably right it looks like that's what TVR did as I've found a TVR site that has a bung listed:
The Cosworth T5 speedo drive has an outside groove machined into it close to the speedo cable end and a small lug of flat metal fits into the groove and is held in place by a small cap head bolt. You should have a small threaded hole just below the speedo drive if it's a cosworth T5.
Theoretically no oil should leak through the speedo drive even if no cable is attached but if the tiny shaft seal is knackered it may do so. . The speedo cable attaches to the drive with an internal circlip, very fiddlely to do so that's one job you have avoided.
Regards Denis
seight
Thanks Denis,
That makes sense now. The box is in the car so it was difficult to see the speedo drive late last night. But I've found some photos I took of the gearbox on my PC and they match what you describe. I think I just need to make the clamp/tab to hold it in place. With a bit of effort I should be able to access it though the ally trans tunnel side panel.
- richardpope50
- Gold Member
Yes, the whole body with cog just pulls out. (Complete with 2 Lt of oil)seight wrote:If I make an entire bung rather than a cap of some sort does the whole drive body just pull out of the case?
Seems like I'll be buying my neighbour a bottle of vin rouge again to make something on his old Myford.
thanks
Regards Denis
