re:oil filter baffling the brain
series3-2007
Post by series3-2007 »
hey guys, heres one thats been baffling my brain for the past few months, where i've the put the v8 into my chassis, some of our measurements were slightly off, and now the oil filter now bashes onto the top of the axle casing (as per picture)
http://invictalandroverclub.com/dsc00814.jpg
any ideas what other filters prefrably smaller fit on the rover filter housing??
spend
Post by spend »
There are some short Ford V6 filters available.
series3-2007
any ideas, where i could get ford v6 filters from?? or somewhere such as real steel?
Post by ian.stewart »
Local Motor factors, depending on what pump base thread you have, Renault 5 fit,
Personally I would be fitting a remote filter, then you can fit the filter away from any possibility of impact, from either suspension travel or foreign bodies hitting it
THE SMOKING GNU
I had exactly this problem, and the only sure fire fix was to fit a remote takeoff plate to the end of the pump, and use a remote filter.
http://www.rimmerbros.co.uk/Item--i-GRID007432
V8Smudge
Post by V8Smudge »
I'm using an adaptor block that rotates the filter out of the way of the diff (it points towards the chassis rail), not sure where it came from, was fitted to an engine I bought with a series conversion adaptor plate.
http://s747.photobucket.com/albums/xx11 ... 370278.jpg
Land Rover SIIA 88" fitted with a 180BHP V8
Some is good, more is better, and too much is just enough!!
V8Smudge wrote:I'm using an adaptor block that rotates the filter out of the way of the diff (it points towards the chassis rail), not sure where it came from, was fitted to an engine I bought with a series conversion adaptor plate. Would love to post some pictures but can't get it to work at the moment.
Easy way to post pics is download your pics to Photobucket, then post direct onto here.
THE SMOKING GNU
V8Smudge
Post by V8Smudge »
Just edited my post, was having problems with photobucket :lol: !
I used a Sierra cosworth filter. Same dia but about half the height of the range rover filter. get one from local motor factor.
Worked fine for me, but (and i'm thinking aloud!) Maybe as it is shorter with I presume the same filter medium it would cause a restriction and so lower oil pressure which could I suppose be an issue on older/ higher mile engines.
DEVONMAN
Post by DEVONMAN »
The filter off an S4 volvo (Halford HOF241) is about 3/4 the length of the rover item and has the same thread. Worth a trip to Halfords and check out different filters. Also the FRAM PH2857A is 3.5" long.
Provided you change it more frequently the shorter filter should be ok.
Regards Denis
