Also, I'm changing my clutch hose, should I be using -4 ?
thanks
Im with the smaller pipe, means less fluid to move less weight on leg, go to extremes, if this was the case race cars fitted with hydraulic brakes and clutches would be running big pipes,Ian Anderson wrote:Longer pushrod?
I'd say shorter
Perhaps master piston is not returning enough to open the "fill" hole from reservoir
Or there is not enough return spring on the slave end thereby fully releasing pressure on the clutch mechanism
1/4 inch clutch pipe is good for quick changes so fluid can move more quickly than through standard brake pipe stuff
IanIan Anderson wrote:Im with the smaller pipe, means less fluid to move less weight on leg, go to extremes, if this was the case race cars fitted with hydraulic brakes and clutches would be running big pipes,
I would be fitting -2, look inside the master or slave cyl, I would be surprised if there is a drilled hole entering or exiting thats much more than 2mm, so putting a bigger pipe on will not have any beneficial points
