topcatcustom
Post by topcatcustom »
What spec is your TB and is your inlet mani ported? Looks good! Got an alternator bracket through for mine but looks different to yours and not very smart so will probably end up making a custom one!
trumpet base is ported twin plenum mate,
and yes the inlet has been opened out too,
did a bit on the starter side today,
using a 4.6 1.4kw starter, although its a smaller body the solenoid still causes a problem on the rubber joint in the steering,
so today the Guys at Caprisport came up with an idea of doing a away with the rubber joint and use two UJ joints, this clears the solenoid with a bout 40mm spare,
next job is to cut up two capri steering couplings so we have the two UJ's needed,
then when its fitted back into the car fingers crossed it still clears :lol: :lol:
i also remembered to take a pic of the powersteering bracket caprisport made while i had it all apart for painting,
and steady brace for the pump itself,
not done much regarding the car/engine recently,
but due to the possible sale of the gearbox and capri/rv8 manifolds
i can order up the new front suspension and the fuel lines,
im working weekends doing private jobs to top the car fund pot back up,
looking like the car will not be back on the road until september now,
never mind, means it can have a long rest ready for a thrashing next year :lol:
at last the fuel lines and fittings are ordered,
been waiting 2 weeks for the hose to be delivered to the UK,
i should have my hose and fittings by the end of the week,
another part ticked off the list,
Post by ian.stewart »
Tony, if y can find the UJ from a allegro or princess, they have the same spline as the ford
THE SMOKING GNU
cheers Ian, 8)
speedo drives arrived today from JRV8,
another part ticked off.
the hose and fittings are now here from Torques.co.uk.
i can see me being a busy guy again :P :lol:
topcatcustom
Spent a bit on that hose I guess Tony! Seems to be so expensive I'm glad I have gone with solid ally under the car, if it is -6 stainless braid and you have any off cuts I may pester you for 400mm after you have fitted it all as that is the only -6 I need !!! Have fun putting it all on- always looks satisfying doing jobs like that 8-)
if you goto the discount section of the forum mate,
http://www.v8forum.co.uk/forum/viewforum.php?f=4
the guy i bought my stuff from is giving you guys on the forum 5% off on hose and fittings, :wink:
started making up the hose from the fuel pump to filter today,
and have the wounds in my fingers to proove it :lol:
does look might pretty though them anodised ends 8) , will get some pics next weekend,
Coops!!!
Watch out for those little sharp ends on the braid mate. They can be quite sharp. Oopps!! Too late :)
thanks for the warning Perry :lol:
here we go:
thats one end done :lol:
only 5 more to do :cry:
started machineing the ends of the new engine mounts today, (yup caprisport let me loose on the lathe :lol: ) and to my surprise they fitted into the channel they were meant to nice and snug, :shock:
as soon as i have some thing that looks like a mount will post some pics,
