I've registered on the forum a couple of months ago. Only reading until know.
Some pics of my pride and joy a '98 Westfield SEight; (For more info click here.)
Getting her registered in The Netherlands (Yep I'm Dutch);
Road tripping the UK last summer #1;
Road tripping the UK last summer #2;
The reason to start posting is that I'm investigating the possibilities of upgrading the power plant. She currently has a 3.9EFI which apart from the K&N Air filter and a Mark Adams fuel map is bog standard.
Piccie of the current installation;
To be honest I'm a little past the initial investigation as I've bought the 5.0 bottom end of Mr. "V8 Jago". Though the project has many uncertainties I'm really looking forward to building the new engine. The aim for the new engine is between the 300 and 330 bhp mark.
For now the spec of my new build is looking like this;
- 5.0 balanced bottom end (Wildcat build) *
- Merlin F85 heads
- ACT Carbon fibre Intake* (on 45mm trumpets *, ~72mm throttle body and ported manifold)
- Up rated injectors?
- Tubular exhaust manifold, custom made.
- Baffled Sump. *
- Lightened TVR fly wheel. *
- MegaSquirt Ecu using Edis8.
- Cam???
Of course the above list is subject to change. Especially the choice of cam is really puzzling me. I want to keep the new engine running on Efi which if I understand correctly limits the choice in cams. At the moment I have the following cams on my list, don't know if they are suited for my Efi setup though. More research to be done here.
- Piper 285 (duration 276/276, Lift .440/.440, timing 31-65 65-31, full lift 107)
- Kent H214 (duration 284/298, Lift .469/.490, timing 31-73 78-40, full lift 111)
- Real Steel Tornado (duration ?/?, Lift .508/.512, timing ? ?, full lift 110)
- Crower 50232 (duration 276/281, Lift .488/.490, timing ? ?, full lift 112)
- V8 Developments H404 (specs unknown, but advised for TVR 500).
Anyway, looking forward to my new build and your comments/suggestions on it.
Regards,
Speed 8.
