p6 clutch master cylinder
waltons
Post by waltons »
Hi all, can anyone tell me what bore master cylinder i need for a rover p6 3500 [four speed] clutch?
was thinking of useing a 5/8th one from a spitfire brake, any good?
thanks.......paul.
good night jim-bob
waltons
Post by waltons »
not the forum to use if you need help then!
good night jim-bob
Post by ian.stewart »
probably nobody has the info for the Master cylinder for a P6, the brake cylinder will work, I keep on changing to and fro between a 5/8 and a 3/4,on my car, [3/4 slave cyl] as I like the sharpness that the bigger cylinder provides but HATE the thing in traffic when you cant hold the clutch down for long,
TBH its probably a "suck it and see" situation, but I would err onthe side of using a cylinder 1 size smaller than the slave and go from there,
Raldes sell master cyls for not a lot of money, so its not that bad if you have to change to a different size.
http://www.rallydesign.co.uk/index.php?cPath=562_582
THE SMOKING GNU
waltons
Post by waltons »
Thanks for that, should have asked you on the nsra LOL,
good night jim-bob
