Does anyone know the spec of these?
I've heard of a few engines now that they've been used on to make some real serious power and wondered if anyone knew anything about them?
5.0 Tvr Griff heads
- ihatesissycars
- HairbearTE
- Guru
Ive heard these described as stage 4, but as stevie pointed out on another thread these stg numbers are pretty meaningless! isnt phil using a 5 ltr TVR in his cobra? if he's using the heads he may be able to advise. About 6months or so ago a set were for sale in the classifieds on here but i think the bloke wanted over a grand for them.
- HairbearTE
- Guru
- daxtojeiro
- Forum Sponsor
Hi there,
I know Rob at V8 development used them on the 5.5L he built, I have a set on my Cobra but havent had them apart. Rob did tell me the valve sizes, etc, but I forget now. Give him a ring.
Phil
Phil
kokkolanpoika
- Knows His Stuff
I ask those heads and valves tvr before i order those stage 4 valves from RPI V8.
Tvr power say those stage4 valves are 43&37mm and valve stem diameter is std 8,7mm. Guides is std gast iron, (not bronze, because those valves are same material as original and original valves dont need bronze guides) but only slightly bulleted. What i understand RPI V8 bronze guides is more bulleted that tvr?
Price is almoust same, Rpi parts is slightly high-priced. But i think why? Because this valve stem diemater is 7,93mm (Racing valves) and exchaust valves are slightly bigger 38mm and guides are bronze.
Timo
