Dave,
That doesn't sound right because you will only get the full 12v on start up and the feed will then revert to the ballasted supply which will only be 6-9v and not be sufficient to feed a 12v coil.
I would re-check what the coil actually requires as a continuous supply.
Ballasted or not.
The whole system will drop voltage when you are cranking, there is no magical connection that gives a full 12 volts when you are trying to start the motor.tetlow wrote:Kevin.
I think the chaps meant that I should have a 12V direct supply too. At least they should, they are the experts.![]()
I have removed the ballast resistor and intend to fit both supplies as I assume a fused 12V would drop when cranking.
Thanks again
The whole idea of the ballast resistor is that your 9 volt coil still gets its full 9 volts when you are ranking, by bypassing the ballast resistor just during starting, then when the starter is let go the ballast comes back into the circuit to keep your 9 volt coil on 9 volts, not 12.
You have a 12 volt coil, so simply run 12 volts to it from your ignition switch, no need for twin wires from starters or any other electrickery like that.
