Composite valley gaskets?????
Whilst playing around under the bonnet today I noticed after turning the engine off a hissing / sizzling noise. It turned out that it was coming from where the inlet manifold meets the cylinder head between the first 2 bolts. There was a very slight water leak that was boiling out of the joint.
Is this just a bad seal with the gasket or am I looking at a major problem?
Will replacing the tin gasket witha composite one help?
Jon
Jon
i must confess i use a small smear on the compo inlet faces,
BUT this time i never and i have a small water leak, it fills the back of the valley up after being left for a few days,
so when i strip the top down and put back together it will defo have a smear this time,
landybob_v8
- Helpful or Confused
i just fitted a comp to mine sealed on the head but not on the intake manifold
hoping it doesnt leak but seeing as im not connected up reaaaly yet i may just whip it back off tomorrow
i never sealed it on the last engine anywhere and come to think of it i had a puddle of coolant at the back of the gasket too but that was probably due to the heater pipes clips forgeting to be tightened and i never bothered to dry it up
i reckon i will pull it back off to seal on the manifold be a pain but worth it
i use hylomar blue by the way
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
mrs happy again
landybob_v8
landybob_v8
the one i fitted was the one that rpi sent me out a year or so back and thats just got the coating
reckon i will pull the manifold off again
pain in the arse taking the injectors off but worth it i reckon
whole reason im putting a new engine in is cos i took short cuts last one and it leaked like a sieve
anyway sorry im thread hijacking here
mrs happy again
mrs happy again
landybob_v8
righty ho going back to this one
i sealed the valley gasket (rpi teflon coated job)
used hylomar around the water ports
once the engine was started must have ran for about 30 secconds and i watched coolant running down the gasket in the valley from around the water port next to cyl number 2
reckon ill try it unsealed next time and see what happens i never sealed it on the last engine and it never leaked
mrs happy again
mrs happy again
