J plate Range Rover 3.9 efi.........
Jono FD3
Post by Jono FD3 »
Would it have the flapper injection system or would it have the later hot-wire efi?? Mite be able to get it cheap (save me rebuilding mine!!!)
Jono
katanaman
Post by katanaman »
should be hotwire
Jono FD3
Post by Jono FD3 »
How do you tell the differance between the 2 setups???
Jono
katanaman
Post by katanaman »
if its all together then the easiest way to tell is by looking at the airflow meter. The flapper has a large sprung flap in the air stream (hence the name) where the hotwire is more or less a straight hole through. There are dozens of other differences but that's probably the easiest one to spot.
Jono FD3
Post by Jono FD3 »
Thank you... shall be looking at it this week I think!!!
Jono
Return to “General Chat Area”
