Ive been having lots of trouble with cold starts, somtimes firing up on 6 or 7, im using a Mallory unilite, promaster coil, HyFire ignition, Plugs are BP7ES whilst it was on the dyno the operator suggested maybe trying a 6 and/or a resistor plug
Any thoughts
Thanks, steve
Engine spec;
5.0 litre with off set ground 86.36 crank, forged 96mm pistons, steel h section rods, stg4 big valve heads, h404 cam kit, 10.5-1 compression ratio,
cloyes chain and gears
adj pushrods
steel rockers
crane hi rev lifters
Quad Weber 48 DCO/SP’s
John Eales manifolds
helix motorsport clutch
lightened flywheel
Powerlite Starter motor (RAC 318)
oil cooler (Stainless Braided oil lines)
