A nice project. Does make me wonder if there is any way to cross over the intakes and get a straighter air flow.
Would injectors be better closer to the inlet port? I've heard arguments both ways on this.
3d printed itb manifold
Re: 3d printed itb manifold
I really don't think the straight thing matters.GDCobra wrote: Tue Apr 14, 2026 7:50 am A nice project. Does make me wonder if there is any way to cross over the intakes and get a straighter air flow.
Injector placement perhaps a little, but then single point injection, carbs etc work fine where fuel is introduced far back. Close to the valve probably favours low speed operation, further back high speed
Reality for most, probably makes little difference.
Those injectors are quite far away from cylinder head.
There are many plastic engine parts on modern engines.scudderfish wrote: Sun Apr 12, 2026 6:22 pmIf your inlet manifold gets that hot, you're probably on fire.
ITB fasteners, water hose connector and blanking plate for rear end water hose hole.
Looking very good.
