Mumford linkage.
Re: Mumford linkage.
mgbloke wrote: Sun Oct 20, 2019 10:49 am Happily the engine is running sweet now after years of grief. The problem would only happen on track and not on rolling road! out of 6 different tuners only one diagnosed the problem to be faulty wiring done by the original installers of the EFI system It has cost a fortune to sort out. Very annoying when you pay good money to so called experts who mess up on the fundamentals. Thanks anyway Mark
Doesn't much surprise me, given the standard of some of the 'pro' wiring I've seen. Bit of a hobby horse here.
I'm not familiar with your ECUs, but MegaSquirt have a logging facility including a tooth log. Which is an easy way of seeing any problems with the tach signal(s)
mgbloke
Post by mgbloke »
Thought I would update. For various reasons I've not used the MG since 2019. While its been off the road I have fitted a dry sump system from John Eales and done further front suspension modifications including dropped spindles and stiffer springs. First time out a few weeks ago and it just makes me laugh how well this thing goes round corners.
mgbloke
Post by mgbloke »
Not sure why this is getting so many views!
I am going to experiment with lowering the rear roll centre height. It was previously set in the middle of three positions making the RC approx. 185mm above ground level. By lowering to the bottom setting the RC will be approx. 130mm above ground level. It will be interesting to see how this affects the balance and traction of the rear. My Front Roll centre is very close to ground level. Predictions anyone?
tylerdavis87
Post by tylerdavis87 »
Interesting project mate. Are you running stock leafs or have you already converted to coilovers? The Mumford setup might behave a bit differently depending on your rear suspension geometry. I’ve seen a few builds where it made the rear end way more predictable though.
mgbloke
Post by mgbloke »
I converted to coil overs at the same time as fitting the mumford Linkage.
