How time flies when your bogged down under a mountain of work.
I cant believe it was March when I last posted and I really have not had the time to work on this up until last Friday evening.
Bloody boats
I got all of the little tiny spot repairs flatted back polished and then waxed.
Next it was out with the gel and slap a coat on.
I did not take it all the way to the edge on the first application as this is just a waste of time and material although on the last coat I did so that when it comes to release time I have an edge to look for in the white against the orange (if that makes sense?)
3 coats of gel were applied in total and allowed to cure overnight so on Saturday I prepared the glass and then opened the can of special heat resistant resin that was made for me.
It is like water and pink in colour as opposed to the normal blue resin that we use on the boats.
With minimal catalyst added to the resin (as I wanted a really slow cure ) The glass was wet out and rollered in the normal way and in a short space of time I ended up with this.
The only thing I did not notice was that the resin fell through the lower sections of the glass at the base of the tube area and has stuck like poo to a blanket on the board that has a material on it !
Best I cut that off then.
Once that is done I will trim the edges and then allow this to cure for a couple of weeks and post cure it as well.
I will explain this post cure process soon as it make a difference.
Back out there tonight so may have some more to show you later.
cheers
P
