RV8 4.6 Induction - Ideas
No - it is just like getting any other OEM ecu remapped.
http://www.tornadosystems.com/shopcontent.asp?type=home
That would be fine if you're sticking to the standard engine. After market ECUs ain't going to be any better than a Motronic and maybe even worse.
But if you modify the engine so the standard map needs changing, it's going to be costly with any OEM unit.
