3 inch single exhaust - power limit ?
Mark
Post by Mark »
I'm building a 331ci - 5.4 small block Ford powered Sierra and have a Cosworth 3" stainless steel system.
Headers are home made 4 into 1 with 1 5/8" primaries and 2 1/2" collectors.
Plan is to connect both the headers to a single system.
10:1 compression, Edelbrock performer RPM heads and EFI intake
30 lbs/hour injectors
Roller cam not bought yet.
Hoping for 350bhp + :?: :?:
Is the 3" system going to be OK?
Looking on American forums I need 3 1/2 inch :?
Ideally you would want a 2 1/4 collector with a single 3" system and 1 5/8 primaries. 2 1/2 will slow the flow in the secondaries just to speed it up again in the single 3" pipe and this causes back pressure and kills any scavenging. A single 3" system is plenty big enough for 350 BHP.
best regards
Mark
Post by Mark »
I'm stuck with the collector size now :oops:
2 1/2" seemed to be the default size when I was looking for collectors :?
It's all welded up now, so not much I can do about it...
DEVONMAN
Post by DEVONMAN »
Slightly off topic but I'd be interested to know what mods were involved to get that T56 into the sierra. ( Tunnel etc) It's on my list of things to do and any pointers would be great. Currently I have a T5 behind a 4.6 twin turbo motor.
Regards Denis
Mark
Post by Mark »
T56 went in fairly easily.
The main problem was around the home brew bell housing, I had to give the transmission tunnel a good beating with a club hammer to get it to clear - no cutting required though.
Other than that there is plenty of room in the stock tunnel, mine is a Mk2 and I think the tunnels are bigger compared to Mk1.
Pic of one of the headers finished, the 2 1/2" collectors don't look too far out of scale to me.
Would going up to a 3 1/2" system counteract any problems caused by the large collectors ?
yes 3 1/2 would be pretty well ideal for 2X2 1/2 collectors. Within about 1% of perfect.
best regards
Mark
Post by Mark »
Thanks Mike.
So it's simply about cross sectional area ?
2 x 2.5" is 9.8 square inches
1 x 3" is 7 square inches
1 x 3 1/2" is 9.6 square inches
I'm not sure how it all works as there is only going to be one bank firing at a time :? :?
Looks like I'm going to be making a 3 1/2 inch system :!:
Collectors arent as straightforward as you'd think..or maybe they're just surprising
Many favour a merge style, where the collector does narrow down, before opening up again into the main system, so the drop to 2.5" wont be a problem.
https://www.youtube.com/watch?v=NekTRPx68zs
And 3" would be no problem at all at 350bhp. Whilst not a direct comparison, I've seen over 700hp on a 2.3 turbocharged engine with a very quiet exhaust, ie 2 large 3" silencers and single 3" the entire way.
n/a is slightly different though, and sizing a bit more important
youtube is good for searching all sorts of info these days. There were other good collector videos I seen, but cant seem to find them.
Not sure how a Sierra tunnel compares to a MK2 Granada
But the T56 fitted into mine fairly easily too. I just removed the original gearbox mount that went up and over the tunnel. Like a second skin about 3-4" wide that created the mount.
Then welded up some new mounts
Although I had already done this for the R154 Supra box anyway. So a little trimming of some lugs off the T56 and it was an easy swap.
It is a big box, and it is a tight fit. But certainly not a difficult one.
Mark
Post by Mark »
It is a heavy bastard though :shock:
Edit to add I did use a merge cone if that makes a difference ?
Not sure about the cone, or how critical it is...or size of cone.
The top end collectors have that cone formed as part of the bends they cut to form the collector, so it's an integral part, rather than a weld on afterwards part.
But from the videos, the taper and "merge" then open up seems to make a good difference. As to how much it affects power, I'm sure that's a huge variable too, as with tube lengths, diameters etc etc.
Just boost it and never worry about all that :D lol
DEVONMAN
Post by DEVONMAN »
Mark,
Thanks for the gearbox pics. Looks good.
It looks like next summer's project on my Son's sierra will be a t56 implant.
I already have a T56 in my hot rod with a Mcleod slide on concentric clutch throw out bearing. I've had a few leak problems with this item so be warned. They include a spare set of seals when you buy it so that sort of tells you something.
Regards Denis :?
simply put yes you aim for constant sectional area, but take the ID not the OD. Stevie is right about the merge collectors. . . but for higher tune engines, with 350 BHP it is really just a case of getting the gasses out, and what you have looks good, you don't have enough overlap on the cam to worry about it.
best regards
Mark
Post by Mark »
Thanks for the replies :D
I'll see what mood I'm in when I finally get to sorting the exhaust system!
I've heard plenty of bad things about the Mcleod bearing, Real Steel assured me they are great :? :lol:
How did you stop yours from leaking ?
DEVONMAN
Post by DEVONMAN »
Mark wrote:Thanks for the replies :D
I put new seals in twice now and at the moment it's holding up ok. Fingers crossed. In my car the engine and box has to come out as a unit to do the job so it's not a quick fix.
